The heating season is coming! Aweshell intranet penetration to realize remote operation and maintenance and data acquisition of heating system
1072
Through the secure connection mode without public network IP and port mapping, it Aweshell help enterprises to realize remote monitoring, parameter adjustment, log collection and fault handl......
As the autumn is getting stronger and the chill is beginning, heating and energy equipment across the country have entered a period of high-load operation. The stable operation of boiler, heat exchange station, gas pressure regulating device, heating pump station, distributed photovoltaic inverter and remote metering system is directly related to the urban heating efficiency and energy security.
For equipment management and operation and maintenance teams, this period of time not only means a sharp increase in workload, but also tests the maturity of remote monitoring and response mechanisms.
How to ensure the continuous online and rapid response of the system without increasing the labor cost has become a common issue for the energy industry.
In the urban heating system, heat exchange stations, boiler rooms and pumping stations are usually widely distributed and have many points. Some equipment is installed in underground or suburban areas, and maintenance personnel have high inspection costs and long response periods.
Gas pipeline network, distributed energy and energy storage system also have similar problems, data dispersion, access difficulties, on-site maintenance is subject to network conditions.
In the face of such problems, Aweray Aweshell intranet penetration is becoming the remote operation and data acquisition infrastructure for more and more heating and energy enterprises.
Through the secure connection mode without public network IP and port mapping, it Aweshell help enterprises to realize remote monitoring, parameter adjustment, log collection and fault handling of equipment in complex network environment, and provide a solid digital base for stable operation of heating season.
Aweray Aweshell intranet penetration: fast, low-cost realization of thermal system remote operation and maintenance and data acquisition
Aweray Aweshell provides safe, flexible and sustainable remote connectivity for heating and energy scenarios through its self-developed intranet penetration technology.
Whether the device is deployed in an enterprise LAN, a private network, or a mobile 4G/5G network, it can establish a stable connection through an encrypted tunnel.
In addition, Aweray Aweshell intranet penetration also relies on BGP multi-line computer room clusters, which can automatically select the optimal link and maintain smooth access in cross-operator and cross-regional scenarios.
For example, in a central heating scenario, the industrial computer of the heat exchange station is connected to the headquarters monitoring platform by deploying a Aweshell client.
When the system detects abnormal pressure or the valve opening deviates from the threshold, the operation and maintenance personnel can immediately check the on-site curve and log through the remote connection, and complete the adjustment and repair within a few minutes without sending anyone to the site.
Engineers can also safely log in to the control system on the remote terminal to obtain real-time operating data, or directly modify parameters and update firmware.
Aweray Aweshell has multiple security protection: the dual guarantee of compliance and stability
The energy and heating industry belongs to the field of high security requirements, the remote access scheme must be operated under the framework of controllable and traceable, and the Aweray Aweshell intranet penetration is fully considered at the beginning of the design.
The Aweray Aweshell supports one-click HTTPS mapping and automatically deploys SSL/TLS encryption certificates to ensure that data transmitted from the browser or client to the server is encrypted.
Aweray Aweshell intranet penetration supports matching flexible security policies, access control functions can be configured in the cloud, such as limiting which IP addresses, which regions, and which time periods can access the system, and access passwords or additional authentication methods can also be set.
Aweray Aweshell also monitors abnormal traffic in real time and automatically intercepts blasting attempts and malicious attacks.
In general, the Aweshell provides an efficient and scalable remote operation and maintenance solution for energy and heating companies through stable and safe intranet penetration technology, so that the equipment remains "online" in the cold winter, so that every time Scheduling and monitoring are accurate and reliable.
Want to learn more about the application of Aweray Aweshell intranet penetration in the energy and heating industry? Welcome to search for "Aweray Aweshell", visit the official website for details or consult an online consultant.
