What Is Network Mapping? How Port Mapping Enables Secure Remote Access Without a Public IP
Marcus ChenMarcus Chen
2026-06-04
Network Mapping
Learn network mapping and how port mapping enables secure remote access without a public IP using AweShell for easy NAT traversal and control.
Remote access has become a normal part of modern work and infrastructure management. However, unstable public IP addresses and restrictions on network devices behind the routers can make it difficult. This is where network mapping can help. It connects you the specific internal services without exposing the whole network. With efficient mapping, you can bypass NAT restrictions. It allows you to access specific ports, programs, or devices in a controlled manner. In this post, we will discuss the working of network mapping and how it enables remote access without a public IP. Furthermore, you will learn how tools like AweShell can help you set it up in an easy and safe way. 图片alt
Network mapping is just like constructing a bridge from your private network to the outside. Only specific traffic is allowed to pass through the route. This process controls the following:
  • Which internal device can be accessed
  • Which router ports are exposed
  • Which user can access the private network
How Network Mapping Works: Basic Concepts and Principles
Here is how mapping actually works:
  1. Your internal device (inside your home/office network) connects to the mapping service like AweShell.
  2. Then the platform creates a secure tunnel to the internal device.
  3. An external user or device connects to the mapping service from the web.
  4. Then, the service forwards the external request to the internal device.
  5. After that, the internal device sends the response back through the same secure path.
Port Mapping vs. Network Mapping vs. NAT Traversal: Key Differences Explained
You may be confused about the differences between port mapping, network mapping, and intranet penetration. Although these terms seem similar they work differently. Here is the key difference between them:
  • Port mapping: It is also called port forwarding. In this technique, a specific port of the router is chosen to forward traffic to the device on a private network.
  • Network mapping: It is a broader term. This type of mapping covers any technique that allows internal resources to be accessed from the outside. Port mapping, intranet penetration, and reverse proxies are part of this technology.
  • Intranet penetration: This technique is used when internal devices do not have a public IP address or are behind NAT/firewalls. A relay or tunneling service helps external users securely access private network services. Here, a cloud-based relay server functions as a mediator. It transmits traffic securely from the internet into your private network.
Why Businesses and Developers Need Network Mapping
Network mapping is used by developers to access the internal resources, such as:
  • Office system remotely for work from home
  • External Tools for API testing
  • File servers/NAS
  • Apart from these, it also helps developers working on distributed systems or cloud-integrated services.
How to Configure Network Mapping Without a Public IP Address
The availability of dedicated public IP is one of the biggest challenges these days. Most ISPs shared or dynamic IP addresses often make direct inbound remote access difficult or unreliable. This is where remote access without a public IP becomes important.
What Is a Public IP Address and Why Is It Harder to Get Today?
Public IP addresses are globally reachable addresses assigned by an ISP, allowing devices or networks to be accessed from the internet. These were given out for free by ISPs a few years back. But today, due to the scarcity of IPv4 addresses, a single public IP is shared among hundreds of users via a system called NAT. This makes getting a dedicated IP address pretty expensive, both for business and residential use.
How NAT Prevents Internal Devices from Being Accessed Directly
Network Address Translation (NAT) acts as a bridge between your device and the public internet. Its job is to:
  • Hides internal IP addresses
  • Shares a public IP with multiple devices
  • Blocks unwanted incoming traffic That’s helpful for security, but it creates an access barrier for the remote workforce.
How NAT Traversal Solves Remote Access Problems
NAT traversal solutions enable systems to communicate via NAT walls. It uses a set of techniques that make direct connections between the devices located behind routers that use NAT. Here are its key features:
  • Build outbound connections inside the network
  • Keeps the session active
  • Routes external requests through regulated channels This technique is commonly utilized in modern remote access systems.
AweShell PHtunnel: Reliable Network Mapping Without a Public IP Address
AweShell provides an organized approach to mapping even without a public IP. Our solution doesn’t depend on generic open source tunneling technologies. AweShell uses PHtunnel technology to establish a secure tunnel between your device and remote users. It runs well on Windows, macOS, Linux, Raspberry Pi, and embedded platforms.
Main Types of Network Mapping
Let us explore different types of mapping methods so that you can choose the best for your use case.
1. Port Mapping
This is the most basic type of network mapping. This includes direct configuration on the router. One internal IP port of the router is assigned to the external port. The port mapping process is simple, but it works with only a static public IP.
2. Intranet Penetration
Intranet Penetration works without a public IP. It bypasses the NAT restrictions via traffic tunneling. You don’t need to do any router configuration in this process. NAT traversal and tunneling solutions are useful when devices are behind CGNAT, firewalls, or private networks without public IP addresses.
3. Reverse Proxy
Reverse proxies are an intermediate between internal servers and the users. They handle the incoming traffic to the private network. Their role is to route traffic to the correct backend servers. Reverse proxies offer filtering of the incoming traffic and increase security.
4. DDNS Combined with Network Mapping
Dynamic DNS links change IP addresses with a fixed domain. When your ISP changes your IP, DDNS updates the DNS record automatically. When you combine DDNS with network mapping, it:
  • Maintains stable domain access
  • Decreases downtime caused by IP changes
Comparison of Four Network Mapping Methods and Their Best Use Cases
Method Need of Public IP Ease of Setup Security Level Best For
Port Mapping Yes Medium Medium Home servers
Intranet Penetration No Easy High Remote offices
Reverse Proxy Yes Complex High Developers, multi-service setups
DDNS Mapping Yes Medium Medium Dynamic IPs with existing router access
Key Factors To Consider When Choosing a Network Mapping Solution
Check the following factors before setting up network mapping:
  • Public IP and Router Permission Requirements: If you’re in rented office space or using a shared network, you will not have access to update router settings. A solution requiring port forwarding access on the router will not work here. You can use the intranet penetration approach here.
  • Supported Protocols: Your mapping solution should support HTTP, HTTPS, TCP, and UDP. A tool that does not support these protocols will leave gaps.
  • Transmission Security and Encryption Methods: Any data that passes via a mapping tunnel can be intercepted. So, choose a mapping tool that offers high-end encryption, not just SSL on the surface.
  • Granular Access Control: Check out whether the mapping tool allows you to control IP, region, and time-based access. This will help you to restrict unwanted connections.
  • Stability and Failure Recovery Capability: The network mapping platform should recover automatically in case of IP change, network drop, and device restart.
  • Configuration Complexity and Maintenance Cost: The configuration and maintenance of the tool need to be simple. This way, even a non-technical user can configure it with the help of a DevOps engineer.
Advantages of AweShell Network Mapping Solutions
AweShell provides dependable network mapping solutions for real environments. Here is what sets it apart from generic tools.
  • Self-Developed PHtunnel Technology: PHtunnel works across systems without complex configuration. It also provides powerful NAT traversal.
  • RSA + AES Dual-Layer Encryption: Your data is protected at every layer with RSA and AES encryption. RSA handles the information exchange, as per ISO-recommended standards. AES encrypts the actual data transmission.
  • No Cloud Data Transfer: Sensitive services and files remain hosted on your own infrastructure instead of being migrated to third-party cloud storage platforms. The tunnel directly connects your internal device to the user.
  • Granular Access Control: Our tool lets you control time access, IP restrictions, and browser-based filtering.
  • Real-Time Monitoring and Alerts: This tool sends you alerts for service downtime, high traffic spikes, and login attempts.
  • BGP High-Defense Data Centers: Redundant routing keeps your mapping stable even under severe load.
Common Use Cases for AweShell Network Mapping
  • Publishing Internal Business Systems for External Access: You can access ERP, OA, or video conferences outside the workplace.
  • Remote NAS Access and File Sharing: Your files stay on your NAS, but you can access them from outside wherever required.
  • Opening FTP Servers for External Access: AweShell creates a secure path so that outsiders can connect to internal FTP servers via TCP. This way, developers and teams can safely share files.
  • Remote Access to IP Cameras and Security Monitoring Systems: AweShell maps security cameras with IP and region constraints so only your security team can see the live feeds.
  • Internal Environment Debugging and Webhook Testing for Developers: You are implementing an integration that sends webhooks to your local server. AweShell gives the server a public URL. That way, services like Stripe or GitHub can access it immediately while developing.
  • Remote Work and Cross-Region Branch Office Connectivity: Two offices in different cities need to share internal systems. AweShell creates a stable, mapped connection between them without setting up a full VPN infrastructure.
How to Create Network Mapping with AweShell (3-Step Tutorial)
Step 1: Download and Install the AweShell Client, Then Log In
  • First, install the AweShell client from the official website on your system.
  • Then create an account and log in.
Step 2: Create a New Mapping with Protocol, Internal Address, and Port Settings
图片alt
  • The next step is to create a new mapping. Here, you need to fill in the internal network host information and application port number.
  • Choose the Protocol (HTTP, HTTPS, TCP, or UDP).
  • Enter the local port your service runs on (eg, 80 for a web server).
  • Select the device or internal IP.
Step 3: Get an Access Domain and Connect Remotely
  • The system generates an access domain. Now you can use it to connect from anywhere.
Advanced Settings: Access Control Rules, Monitoring, and Alerts
After creating the mapping, you go to the settings. Here you can:
  • Add IP filters
  • Set time schedules
  • Enable traffic monitoring
Best Practices for Network Mapping Security
  • Open Only Necessary Ports to Minimize Exposure: Every open port is a potential access point. So, you should map only those services that genuinely need external access.
  • Enable IP Whitelisting and Regional Access Restrictions: You can block traffic from areas that you don't work in. This greatly reduces automated scanning and brute-force attempts.
  • Set Time-Based Access Rules to Disable Access Outside Working Hours: If your team is working 9 to 5, there is no need to keep your private network accessible at 3 am. With AweShell, you can establish active hours for each mapping.
  • Enable Traffic Monitoring and Alerts for Abnormal Access: Setting traffic thresholds and enabling service monitoring can be beneficial. If traffic rises suddenly or a service goes down, you will get an instant alert.
  • Review Mapping Rules Regularly and Remove Unused Connections: Outdated mapping can bring a security threat to your network. Therefore, you should review your mappings every month and clean up what is no longer used.
Frequently Asked Questions
  • Can AweShell Create Network Mapping Without a Public IP Address? Absolutely yes. AweShell supports remote access without a public IP address. This is done via NAT traversal.
  • Does AweShell Support TCP and UDP Mapping? Yes, both TCP and UDP protocols are supported by AweShell.
  • Will Remote Access Become Slow After Mapping? Not significantly. AweShell uses a high-performance relay infrastructure with a BGP data center. These technologies maintain a stable and fast connection speed.
  • Does AweShell Work with Windows, Linux, macOS, and Raspberry Pi? Yes, it supports Windows, Linux, macOS, Raspberry Pi, and an embedded SDK platform.
  • What Is the Difference Between Enterprise and Personal Plans? AweShell's personal plan is for individuals with simple mapping needs. However, our enterprise plans are meant for businesses with multiple users. These are equipped with a wide bandwidth and more tunnels.
Network mapping allows you to access systems of a private network from outside in a controlled way. It allows you to perform secure remote operations. Setup can become more structured using mapping tools like AweShell. It doesn't even require a public IP. More than 18 million users are already registered on AweShell for secure remote access. Our plans are flexible and available for both individuals and enterprises. Download AweShell and create your first mapping today. If you have any queries, our team is ready to assist.
Marcus Chen
Marcus ChenNetwork Analyst
Marcus focuses on real-world networking and remote connectivity for AweShell. He explores NAT traversal, internal network access, and connection performance in distributed environments.
